cRIO error
My cRIO runs in FPGA mode. I created a FPGA VI which scans all available IOs in a while loop.
On my main VI, it opens the FPGA reference and reads the IOs in a while loop. I read this error from the console out.
-> 0x181c8d8 (Main Application Thread): memPartAlloc: block too big 602520 bytes (0x10 aligned) in partition 0x37e360
What's causing this?
Thanks in advance!
Message 1 of 9
(5,268 Views)
Which cRIO are you using and what modules are installed?  What version of Labview software?  Can you post your code?
Message 2 of 9
(5,259 Views)
I'm using cRIO NI - 9012. with 60+Mb memory.
From my findings, with the full software package install, i'm only left with 6+Mb memory to work with. Therefore, i un-installed all software components that are not required, which in turn increase the free memory to around 50%, ~30+Mb. AND everything works fine.
Anyhow, thanks for the reply.
I'm wasn't aware that LV software consumed so much memory. My Bad.
Message 3 of 9
(5,254 Views)
You may still want to take a hard look at your code to see if it can be modified to reduce its memory requirements.
Message 4 of 9
(5,252 Views)
I did a simple test; have a clean 9012 installed with the software and not running any application. Below are the screenshots of the MAX and System Manager. The figures don't seem healthy at all.
Message 5 of 9
(5,103 Views)
Are you using shared variables?  If so how many and what kinds of data types?
Message 6 of 9
(5,101 Views)
In my last post, i just used a 9012 with only NI software installed. I didn't run any of my application.
FYI, i did a memory profile on my application. They are negligible: < 6kb.
As for mem leak, i did 2 steps, first i capture the RT execution trace and found no dynamic mem alloc, secondly i test ran my app overnight and log the system variables, eg CPU util and memory consumption.
Lastly, i uninstalled most NI software and was able to get ~12MB of memory.
Just wanted to share my experience. Cheers! 😄
Hope this helps!
Message 7 of 9
(5,099 Views)
Hi
What modules have you populated the chassis with?
Which chassis is connected?
What software is loaded on the RT?
Regards
xseadog
its the questions that drive usSmiley Tongue
Message 8 of 9
(5,082 Views)
This chassis \that i'm using is cRIO 9111
Modules: 9425, 9205
I only installed, LV RT, VISA (Serial & USB),  Scan Engine, RIO, Network shared variables and other depencies.
Message 9 of 9
(5,075 Views)
