WPT with a sbRIO
I am having difficulties creating web publising html for a vi that is running on the RT of an 9631sbRIO. I get the dreaded invalid IP error when the web page loads.  The boarder and title of the page load, but in the middle i get an IP error pop up after some time. Can someone describe in detail what i need to do to run this on a RIO.. I have run WPT at home succesfully with a simple stand alone VI, but I can not run it at work with a simple VI or on a sbRIO platform. Do I need to install code to support WPT on the RIO itself? Any other info would be great...
   Keith
(3,550 Views)
I'm not sure what you mean by the "title" and "border" of the page.  Do you mean you're using remote front panels and the VI's front panel won't load?
You should also make sure that you have the web server enabled and configured on the cRIO.  You can do this in your Project Explorer window. Right-click on the target and select Properties.  Then, you should see the category "Web Server".
Furthermore, here's another similar post I found with some good details and reference links that may be of some help to you:  http://forums.ni.com/t5/Real-Time-Measurement-and/Remote-view-control-of-cRIO-VI-on-a-general-web-br...
(3,538 Views)
Hi Rory,
   Yes, I am trying to use the web publishing tool to create a remote front panel for a deployed RT application runing on an sbRIO. Can you help walk me through this. Your example link does not open either... I got a nNI discussion forums page not found error.
   Keith
(3,521 Views)
For whatever reason, the above link was missing the "t5" near the beginning. The link below should work.  Try looking at Adnan and JamesC's responses.
Remote view/control of cRIO VI on a general web browser
Hope this helps!
(3,513 Views)
