Writing value to specific Cell in Excel Sheet Using ActiveX in LabVIEW
I need some help to insert some data to specific cells in Excel In LabVIEW. Im using Active-X for executing this. Its show errors while running it. Errors are attached in this post. But. while running it in"Highlight Execution mode", it shows no errors. Please help me on this.
Is there any alternative method other than using Active -X for writing data to specific cells. Thanks in advance.
Shaz M Rahath
(5,305 Views)
Hi Shaz,
Sorry that I can't help you with that error, but I can tell you that you're likely to get a faster answer if you post this on the LabVIEW forum, rather than the Real-Time Measurement and Control forum. This thread will be managed by the right people over there.
(5,275 Views)
I think it will be good and easy to use LV Report generation MS toolkit, u will find examples and it's easy to modify it as u want.
Abdallah Farmalawi
(5,205 Views)
Please have alook in
https://decibel.ni.com/content/docs/DOC-2081
Abdallah Farmalawi
(5,201 Views)
