01-09-2007 09:07 AM
01-10-2007 02:09 PM
Hello Thisisnotadream,
Since all of the VIs are being used in the VI why not use them as subvis? Calling the subvis from your main application will not be painful and will only incur slight overhead compared to setting up and calling VIs using VI Server. I have been having difficulty following your problem. Are you currently running your VI from the development environment or is it already a startup executable. Perhaps posting a subset of the code causing the problem could give us insight for how you are trying to go about calling these VIs.
Steven T.
01-10-2007 02:21 PM
01-11-2007 11:21 AM
01-12-2007 07:16 AM
01-15-2007 10:35 PM
01-24-2007 12:35 PM
