‎07-26-2008 11:09 AM
‎07-29-2008 01:52 AM
‎07-29-2008 07:23 AM
‎07-30-2008
07:38 PM
- last edited on
‎09-04-2025
01:32 PM
by
Content Cleaner
Hi Dwisti,
The link you provided indicates that the Addonics IDE to CF adapter is not supported on ETS. Also, the Requirements for a Desktop PC as a Real-Time Target gives the hard drive requirements as Parallel ATA (IDE) or Serial ATA (AHCI) with the FAT32 file system on the primary partition of the drive. However, you did not indicate if you want to boot ETS from the CF or simply use it as storage. If you're trying to boot ETS from the CF, you can try the instructions in How Can I Test My PC For Compatibility with LabVIEW Real-Time or LabWindows/CVI Real-Time for Deskto... The tool will evaluate the hardware in the PC for compatability with ETS. It would be an interesting experiment.
