TCPDUMP in RT Linux on cRIO
@Jonas_A wrote:
I get the following error when I try to enable the server.
I tried everything that is suggested here but it doesn't solve the problem:
“SSH Must Be Enabled on the Target” Message Displayed When Adding Software to NI Linux Real-Time Tar...
Real-Time Software
Something went wrong while getting the installed and available software.
SSH must be enabled on the target.
OK
Did you format and install your cRIO target using legacy method or the System Image?
The legacy installation does not enable SSH by default. See Accessing the Shell on NI Linux Real-Time Devices to enable it.
The system image installation enables SSH by default as the NI MAX uses SSH to carry out the installation.
https://tmesystems.net/
Message 11 of 13
(721 Views)
SSH is enabled in Linux node, I can SSH from the machine where I installed NI MAX.
Message 12 of 13
(717 Views)
Is it possible just to transfer the packages I want to install directly to the cRIO so I don't have to setup the server etc?
BR
Jonas
Message 13 of 13
(697 Views)
