TCPDUMP in RT Linux on cRIO
It seems that TCPDUMP is not included in the Linux installation. Is there away to install this application so that we can sniff an ethernet interface?
BR
Jonas
Message 1 of 13
(1,107 Views)
You can use Raw Ethernet Frame Decode and Encode Example. Follow the instructions in the readme to install the library for Linux RT.
Alternatively, you install the package from NI feed. See Solved: Wireshark and libpcap
Control Lead | Intelline Inc
Message 2 of 13
(1,079 Views)
TCPDUMP is available through the OPKG package manager:
>> opkg install tcpdump
Message 3 of 13
(1,053 Views)
Seems like tcpdump is not part of the installation:
admin@EBS9-1:~# opkg install tcpdump
Collected errors:
* opkg_prepare_url_for_install: Couldn't find anything to satisfy 'tcpdump'.
admin@EBS9-1:~#
The linux machine doesn't have internet access.
Message 4 of 13
(981 Views)
It's possible to download the needed packages for TCPDUMP on your desktop PC, copy it to the cRIO and then install it. I did this several times, also with TCPDUMP. Here is a short tutorial and tipps: https://dokuwiki.hampel-soft.com/kb/ni-rt/linuxrt/opkg#installation_of_packages_on_offline_devices
Regards
Manu
Message 5 of 13
(975 Views)
Which .ipk file should I download to install TCPDUMP?
Jonas
Message 6 of 13
(949 Views)
The tcpdump is included with the NI Linux RT System Image Feed. If your controller does not have access to the internet, follow the steps in Offline installation of OPKG packages on Linux Real-Time devices
Message 7 of 13
(946 Views)
The windows server with which I connect to the cRIO neither has internet connection. Is that a problem if I use NI Linux Real-Time Offline Installation Support  ?
Message 8 of 13
(941 Views)
You can use another PC that has internet access to download the NI Linux Real-Time Offline Installation Support, then install it to the machine without internet access. The machine will then act as the feed repo server for the real-time target. No further internet access is required.
Message 9 of 13
(938 Views)
I get the following error when I try to enable the server.
I tried everything that is suggested here but it doesn't solve the problem:
“SSH Must Be Enabled on the Target” Message Displayed When Adding Software to NI Linux Real-Time Tar...
Real-Time Software
Something went wrong while getting the installed and available software.
SSH must be enabled on the target.
OK
Message 10 of 13
(891 Views)
