Start up application issue with cRIO 9063
Hi I am having issues with my cRIO-9063 booting into "Install Mode".
I have two cRIO-9063 running the same vi.  The cRIO has had the ni-rt.ini file modified to run my vi form.vi on start up. Both systems have been running fine since august.  This includes a number of restarts.  Then, this week, the power was cycled for cRIO number two.
  When the cRIO booted back on, it is now in "Install Mode".  I still have access to the web interface, and I can boot it into Safe Mode.  However, I have no idea how to get it out of install mode.
  Also, is there some mistake I made that lead to the cRIO being stuck in install mode?
Thanks for any help, and please let me know if you need more information
(3,284 Views)
Accepted by topic author samtbacon
To answer my own question.
My issue was I had used up the memory on the cRIO in install mode.  The disk space had gone to zero, and was booting into install mode as a result.
I enabled SSH shell script, remoted in, deleted the impeding logs, and cRIO works fine.
In my code, I had an auto error log function for certain errors.  cRIO one, had few errors.  cRIO two, had a lot more.  As a result, cRIO number two filled up its disk first.
(3,270 Views)
