SIT cRIO 9025
Hello Alisha.
can you look at my bitfile. Now i am try to uninstall all programs and do everything again from begining.
Regards.
Sinan Başaran-GYTE
Message 11 of 18
(3,164 Views)
Hi Sinan,
Since I don't have knowledge of your system, I can't tell if the bit file is correct but it looks like you successfully created one.
As you're going through the installation process, can you do a few tests for me? We need to know to what extent the system is working properly.
1) Can you run an example model (like the sine wave model) in the simulation environment? This will help us know that the installation was successful.
2) When you've verified that you can run an example in simulation mode, then start working with the .OUT files, etc to run on your cRIO. If you need assistance at this point, please post screen shots of your cRIO software, of the mapping you've set, and of all the dialog boxes in SIT Connection manager that you've changed things on. It's hard for me to make any helpful suggestions without knowing more details about your system and setup.
3) Are you able to deploy a regular VI (no SIT stuff) to you cRIO?
Message 12 of 18
(3,145 Views)
Hello Alisha P
i think my problem is related to sinwave_Driver.vi
when I try to run it it gives a error.
'' SubVI sinewave_Base Rate Loop.vi Sub VI is not executable.''
i attach the screenshot and dirver.vi can you check these.
Regards.
Message 13 of 18
(3,136 Views)
The sinewave driver should work out of the box with no issues by following the directions. I would try them once more from the top and if it still doesn't work, we can see what's going on. I would recommend you see where in the driver those errors are coming from because I am not seeing them on my end.
Ben D.
Message 14 of 18
(3,122 Views)
Hi Sinan,
Also, have you tried any of the other shipping examples? They should all run out of the box, but perhaps your sinewave one has somehow been altered? Do you get a similar error with all of the shipping examples?
(Are you able to run any example in the simulation environment?)
Message 15 of 18
(3,116 Views)
Hello
Sinwave  example run in the simulation environment with no error but the problem is generating the sinwave driver.
NI Turkey Applications Engineering's is run the sinwave example with SIT by editting some staff in sinewave_driver (which ones are I dont know.)
the problem is cRIO 9025 is have problem to generate sinwave driver. And other ......_driver.vi
Message 16 of 18
(3,107 Views)
and also generated driver.vi is a fgpa in normal mode then we change it to the dynamic mode.
And finaly sinewave example work with the SIT.
but the extra problem is:
the example sinwave problem matlab model is 0.005 fixed step size.(0.2 kHz)
i change the step size to the 0.00005 fixed step size (5E-5) (20 kHz)
then it gives the error 14120 it is in the attachments picture.
how can I work cRIO 9025 and SIT with higer step size 20 kHz or more.
Regars.
Sinan Başaran - GYTE
Message 17 of 18
(3,104 Views)
Hi Sinan,
From the error message, it looks like you're trying to run this particular model faster than it can handle on your system.
A colleague of mine is working with your NI branch to figure out what your options are. They will continue to assist you.
Message 18 of 18
(3,080 Views)
