11-05-2025 06:49 AM
i have a code running on a cRIO-9040. The code runs on the RT part and FPGA (cRIO Programmed in FPGA mode).
The RT part is handling data acquisition and control through C-series modules.
We do have an existing cloud solution that i now want to integrate on the cRIO. The existing code handling the data stream to cloud is written in python.
Questions:
1.
Is it feasible to install python on the cRIO-9040 and running the python code in parallel with the existing LabVIEW RT code?
The python code is not time-critical and data will be passed from LabVIEW RT code ty python codeevery 30 sec or so.
2.
Data from LabVIEW RT code to python code will be passed as a TCP/IP package through localhost. This is reusing existing method that works fine on PC targets. My question is: Is there any built-in restrictions/firewalls etc. on the cRIO that will prevent such an approach, i.e. passing data between different applications through TCP/IP on localhost?
11-07-2025 03:08 PM
I do not really understand your question. If you are asking if you can send data from a LabVIEW application to a python code, then yes. If you are asking if you can program a cRIO using python, the answer is no. I am currently doing a very similar application where I have programmed a cRIO to acquire data (the data is being sent through DMA FIFO from the FPGA). I am sending the data from the RT side to raspberry pi, programmed with python. I haven't had any problems. Here is my RT application and python code for reference. Be advised I removed a lot of the labview block diagram code to show the essence of sending data to a port via TCP/IP connections. In the middle of the flat sequence structure I have two loops.
In loop 1:
I am getting the data from the FIFO and enqueueing the data
In loop 2:
I am dequeuing the data and writing it to TCP write
Here is python code:
import socket
from matplotlib import pyplot as plt
from struct import unpack
HOST= '192.168.X.XX'
PORT = 6340
# Create socket and pull data
with socket.socket(socket.AF_INET, socket.SOCK_STREAM) as s:
# set rx buffer size
recv_buf_size = 4096
s.setsockopt(socket.SOL_SOCKET, socket.SO_RCVBUF, recv_buf_size)
s.connect((HOST, PORT))
print(f"Connected to {HOST}:{PORT}")
# Receive the length of the payload
len_bytes = s.recv(4)
length = int.from_bytes(len_bytes, byteorder='big')
print(f"Length: {length}")
if length > 1000000:
print("clipping")
length = 1000000
# Pull the actual data
got = 0
buf = bytearray(length)
view = memoryview(buf)
while got < length:
nread = s.recv_into(view[got:], length - got)
if nread == 0:
raise ConnectionError("closed")
got += nread
print(got)
print(f"RX length: {len(buf)}")
format_str = ">" + "h"*(length//2)
decoded = unpack(format_str, buf)
#print(f"Data: {decoded}")
# Send Close request
plt.figure()
plt.plot(decoded[0::2], label="CH1")
plt.plot(decoded[1::2], label="CH2")
plt.legend()
plt.show()
Furthermore:
If you have more questions, please ask. If this was all you needed please leave a kudo and 'Accept as Solution'!
11-10-2025 05:39 AM - edited 11-10-2025 05:43 AM
Hi and thanks for the answer.
To clarify my question:
I already have the LabVIEW code running on the cRIO. I want to add functionality to stream data to a cloud solution directly from the cRIO, instead of having a device in-between.
Since our existing cloud solution for data stream is implemented in python, and the cloud solution vendor provide python functions handling the communication to the cloud, i wanted to investigate if it is feasible to run the python code on the cRIO, at the same time as the LabVIEW application runs on the cRIO..
As cRIO is a linux machine, i was wondering if it is possible to install python on it, and if it is actually possible to run the python code in addition to the LabVIEW real-time code.
I am aware that running python on cRIO in parallell with LabVIEW RT is most likely not supported by NI, i but i want to investigate the possibility of such a setup
11-10-2025 09:42 AM
This is very interesting problem to solve. I do not have the necessary knowledge to answer your question, but I did find these links that might help...
1.) GitHub - ni/nifpga-python: Python API for LabVIEW FPGA devices
2.) Integrating Python Code in LabVIEW - NI
3.) Python Resources for NI Hardware and Software - NI
4.) Set cRIO Programming Mode With a Python Script - NI Community
02-09-2026 09:20 AM
We are using cRIO9033. Not sure if the info also applies to cRIO9040.
Make sure you set a secure admin password (blank or "1234" is not secure!)
Turn on SSH on cRIO in MAX, reboot.
Connect cRIO to an internet capable ethernet line (behind a firewall, so that your cRIO is not reachable from the internet but your cRIO can reach internet).
Connect to cRIO via SSH (e.g. with putty, kitty or similar ssh capable application) from your working machine (laptop, desktop, ...); login as admin with your secure admin password.
On the command line (assuming you know how to use linux command line):
"opkg list" --> lists packages
"opkg install <package>" --> downloads and installs packages
You might be interested in python packages, so grep them from the list.
Not sure if pip is installable, we never needed it on cRIO.
If internet connection is not possible you can download the required packages from NI via web browser; URLs can be taken e.g. from /etc/opkg/base-feeds.conf.
Transfer the files to your cRIO via SFTP and use the "opkg install" command with the downloaded packages.
As I remember python was already installed on our cRIO.
Python can be run on cRIO whenever you want (e.g. via command line via ssh). If you want to start your python application automatically you can write as service script or write a start script which you start from /etc/inittab (not sure if this is applicable for your cRIO).
