Example Code
Set cRIO Programming Mode With a Python Script
Products and Environment
    Operating System
  • NI Linux Real-Time
    Programming Language
  • Python
Code and Documents
Description
This example shows how to use the NI System Configuration Python API (nisyscfg) package to read or set the programming mode of modules in a cRIO device with the NI Linux Real-Time OS. This can be useful if LabVIEW is not the main programming language being used in an automated test scenario.
How to Use
  • Running nisyscfg requires the NI System Configuration software to be installed in the cRIO. Refer to Adding or Removing Software on Linux RT Targets for information on how to add/remove software.
  • The nisyscfg package supports CPython 3.5+ and PyPy3.
  • To install the nisyscfg package you can install python-pip first from the cRIO command line and then use it to install nisyscfg:
    1. opkg install python-pip
    2. python -m pip install nisyscfg
    3. If the previous line errors out, you can try using "sudo easy_install pip==9.0.3" instead.
  • The attached files are named get/set property, as not only the Programming Mode can be changed with this method. The API files, like properties.py, shows other available properties.
Additional Information
You could also leverage a similar script and execute it remotely using SystemLink salt states. If included in a SystemLink custom salt state, the state can be defined as:
mycommand:
  cmd.run:
  - name: python <script_location>
  - runas: admin
Related Links
Contributors
