RTGetTimestamp.vi
The RT Get Timestamp.vi help says:
Inserts a 64-bit timestamp value from a high-precision timing source into a preallocated array at an index value specified by iteration.
What is the high-precision timing source?  I want to know the speed of this source, so I know how much time has elapsed per bit changed.
Fred
*Kudos are appreciated.*
(3,649 Views)
Using the RT Get Timestamp.vi on a PXI-8104 embedded controller (http://sine.ni.com/nips/cds/view/p/lang/en/nid/204820) I found that
timestamp_t2 - timestamp_t1 = 1000 corresponds to 1us.
This would imply that for the 64-bit timestamp value from a high-precision timing source 1 bit change corresponds to 1ns, and thus the high-precision timing source clock is 1GHz.
This seems reasonable since the PXI-8104 uses a 1.86 GHz Celeron (as found from the link above).
Can somebody confirm the above?
Fred
(3,644 Views)
Accepted by topic author FLng
I looked at the RT Timestamp Analysis.vi and found the RT Get Timestamp Frequency.vi.  (It's located in the rtutility.llb.)
I used RT Get Timestamp Frequency.vi in a vi on the PXI-8104, and the frequency was 1GHz (confirming the previous message).
Fred
(3,641 Views)
