Query Regarding CAN Message Transmission Behavior in NI-XNET Bus Monitor
Hello All,
I'm using the NI-XNET Bus Monitor to log CAN communication. During testing, I’ve observed a critical issue: all transmitted messages on the CAN bus stop unexpectedly, while received messages continue to appear active. The bus also seems to remain unloaded during these events.
In some cases, this behavior occurs even when no active testing is being performed, which makes it difficult to pinpoint the cause.
My main concern is understanding why the bus stops transmitting messages. Could this be related to the configuration or behavior of the NI-XNET Bus Monitor?
Additionally, I’d like to confirm the following regarding Listen-Only Mode:
  • What is the default setting for Listen-Only Mode in NI-XNET Bus Monitor?
  • Can enabling Listen-Only Mode impact bus load or message transmission?
  • Is it possible that having Listen-Only Mode enabled causes the transmission to stop?
Any guidance or shared experiences would be greatly appreciated.
Thank you!
(140 Views)
Yes, as the term suggests, a listen-only mode does not transmit CAN messages.
Use subordinate mode to monitor all outgoing and incoming messages.
https://tmesystems.net/
(123 Views)
Hi All,
How to permanently/default disable the Listen Only mode in NI Xnet Bus Monitor? I am using the Ni Xnet 2017 version
(100 Views)
@Mapwar96 wrote:
Hi All,
You cannot disable the Listen Only option. It is already not selected by default. Simple don't enable it.
(85 Views)
In NI-XNET Bus Monitor 2017, the "Listen Only" mode is enabled by default on one of the four CAN buses in my setup. I’m unable to disable this mode or configure it to be disabled by default. Interestingly, the other three CAN buses do not have this issue — "Listen Only" is disabled on them by default.
(75 Views)
