11-02-2012 12:00 PM
Hi all,
As every beginner says, I am new to LabVIEW and NI products.
I want to control a hydraulic proportional valve and a servo hydraulic valve. I found some examples but I couldn't get the idea. Let's say valves are at beginning position at 0 V and are at end position at 10 V. I want servo valve to operate at 10 Hz and -+10 mm stroke. I don't know how to create a block diagram which includes the motion that I need. I know the stroke and the frequency depends on something else too (like cylinder, hydraulic pressure of the tank, etc.) but I can't find the proper block diagram for this motion in VI.
In other words, I need to find the voltage value which lets the servo valve move like I wanted. I mean will -+5 V input value make that movement? If so, what is needed for that motion to be 5 Hz?
Also I need to apply that algorithm in my VI. How should I proceed?
Any help is appreciated.
Thanks in advance,
11-02-2012 07:32 PM
Hydraulic valves are typically velocity based actuators - that is if you apply 1V it will generate a certain flow rate, and hence speed of a cylinder or rotary actuator. Double the voltage and it will move approx. twice as fast.
So if you know the gain from volts to speed you can calculate the volts needed to produce a certain trajectory (10Hz, +/-10mm travel).
However, this form of open loop control wont be so repeatable, so is more often done with a feedback controller, where you define a setpoint to match the desired trajectory and compare that to the a measurement of the actual position and the error is fed into a controller (e.g. PID), the output of the controller is connected to the volts of the servovalve. If the controller is tuned correctly then the cylinder length with follow the desired trajectory closely.
You can combine this feedback control with the open loop control (feedforward) so that they both help each other.
Hope this is a useful start.
11-05-2012 09:15 AM - edited 11-05-2012 09:15 AM
03-09-2016 02:58 PM
Hi did u get a solution on how to control a proportional solenoid valve? I also have a challenge. I'm trying to design a block diagram to control this valve using compact rio9074.
03-09-2016 03:37 PM
What part of the system don't you understand - the concept of feedback control, the interfacing to the valve, how to realise in realt-ime LabVIEW?
There are plenty of application examples to show you the fundamentals.
03-10-2016 12:32 PM
Thanks for the reply.
Actually I'm doing my internship in a company. They gave me a compact rio 9074 and Labview software They showed me an airbrake system of a locomotive. their main objective is for me to :
1. Design a labview program to monitor and read the Pressures of the air reservoirs in the airbrake.
2. Send an output to open the valves for dumping the air
3. And setup a multi-client Server system so all the computers in the network can be able to access the airbrake unit
At this point in time, I have been able to designed the multiclient server system using the STM in NI website.. I'm able to read the pressures from all the reservoirs. and send them over the entire network.
The challenge I'm having now is to control those valves from my host computers. I wanted to use the PWM option in Crio, but the Crio 9074 they gave me doesn't have that option activated. It only have the counter and the quadrature options for digital signal.
The airbrake has two proportional valves, digital and analog valves. I was thinking of using a PID Controller since this valves are proportional but don't really know how to do it or maybe some other way.
I have a copy of the data sheets for the valves
03-10-2016 04:52 PM
By "dumping air" do you mean continually adjust the valve to keep the pressure(s) at a target value ? Just to make sure we are talking about a feedback control and not some tiype of logic / automation system.
If you need a PWM to adjust how fast air is dumped, then it should be fairly easy to program one from first principles - but even easier to get the required components activated. Especially as if thar is not there then other useful blocks you will need might also not be present. The PWM only allows you to drive the valve with a variable signal, to make a feedback controller you will also need
hope this helps - and not too basic
03-11-2016 03:15 PM
Hi Andyclegg,
By dumping air l simply mean opening at a desired voltages. The valve can be controlled with an input of 0- 10v. this opens the flow rate at the particular voltage and allows air to be release from the unit. Yes a PWM code is kind of easy to design but the challenge here is, the compact rio 9074 module won't support the PWM. It only supports counters and and quadratures. but from the data sheet of the valve, it is clearly stated that only the PWM can be used to control the valve. The valve is a Burkert Type 6223 and the controller used to control it is Burkert Type 8065
03-11-2016 03:18 PM
sorry type 8605
03-11-2016 03:38 PM
OK so you have an external elecronics module (the 8605) which converts an analogue voltage or current into a PWM signal that can drive the valve.
Why do you think you need a PWM in the cRIO ?
