Problem with ftp
I cannot get ftp to work with a cRIO-9012 Controller. It used to work with LabVIEW 8.6.1, but our IT department has forced us onto Windows 7, so I'm forced to use a newer LabVIEW.
I can get access, but cannot do directory listings or transfer files. What I can and can't do can be seen in the Command Prompt screenshot below:
I can ftp in, I can log in, I can change directories. However, the ls command results in everything hanging. I need to ^C to regain control.
I can open files in Internet Explorer or Windows Explorer, but not using Command Prompt commands. I need to get the Command Prompt method to work so that I can use the System Exec.vi to automate the process.
I'm using Windows 7 Enterprise, NI CompactRIO 14.0.1 - August 2014.
(5,149 Views)
Thanks to my work colleague Peter, this is now solved. As probably expected, it was a permissions issue. The website http://superuser.com/questions/215775/command-line-ftp-function-does-not-work has the solution, which is shown below.
I had an issue with transmitting files via FTP once I was logged into the box in question. It would create the file name, but the file was empty. I resolved by doing the following:
  • go to Control Panel → Windows Firewall → Advanced Settings → Inbound Rules
  • double-click the Name column to sort by name
  • scroll down until you see two rules called "File Transfer Program"; these were set to Block on my PC (big red circle with a line through it)
  • double-click on the rule
  • on the General tab, under Action, set to "Allow the connection"
  • click OK
  • do this for the other rule
Vito
(5,137 Views)
