07-15-2010 08:37 AM
I am attempting to conduct real time voltage monitoring from NI-9201 module. This is connected to the NI-9104 rack through compact rio 9104 inot labview. The MAX has all the correct software installed and the 9201 module is depicted in slot 1 in project explorer. When I run the DAQ assistant, under the supported physical channels the message is 'No supported devices found'. I have attempted to resolve this problem by altering the file location in the file management tree to no avail. I can communicate with the real time module and the FPGA in MAX explorer but not within a project, the DAQ assistant should be able to see the NI9201 device.
Have I missed something simple!
07-16-2010
08:22 AM
- last edited on
09-26-2025
07:19 PM
by
Content Cleaner
Hi there
The reason you are incurring this error is that the DAQ Assistant Express VI is not the best solution for using in Real-Time.The best advice however would be to not use the DAQ Assistant with LabVIEW Real-Time. Instead, use the explicit NI-DAQmx VIs located on the Measurement I/O » NI-DAQmx palette. These VIs have much less overhead than the DAQ Assistant.
I have referenced some links below to get you started via our Developer Zone.
DAQmx examples can also be found in LabVIEW » Help » Find Examples... » Browse by Task » Hardware Input and Output » DAQmx
These low level VI's are suited for use when programming in LV Real-Time. You will also need to install DAQmx drivers if you haven't already done so.
07-16-2010
01:39 PM
- last edited on
09-26-2025
07:19 PM
by
Content Cleaner
Actually, the reason you're getting this error is because CompactRIO does not support the DAQ Assistant. I think the previous poster mistakenly thought you were using a CompactDAQ chassis as opposed to CompactRIO. Both of these systems support using the NI-9201 input module, but the programming is different. For an introduction to programming cRIO see these tutorials:
For a more extensive guide, see:
Gerardo
07-19-2010 06:38 AM
Thanks guys for your help, I will read the information on the link. Hopefully it should solve my issue
