NI-Serial does not install on RT Target
We have NI Developpers Suite 2011 installed on a Windows 7 PC and a RT NI-PXI System with 8102 RT Controller.
We need to use the RT Controller COM Port for serial data communication. I learned that we need to install NI-Serial on the RT System to be able to do so.
Unfortunately we have issues in installing NI-Serial V3.8.1 on the RT device.
I installed NI-Serial on the Windows PC and I can see it in the MAX-Explorer - so far so good.
But when I try to install it on the RT System (via MAX) NI-Serial does not appear on the list of SW to install.
Any suggestions on how to install NI-Serial on RT System are welcome. System information will be uploaded soon.
Regards
(5,315 Views)
Hi Norman,
I think you forgot to install the RT-Version of the driver.
Here is a KB which explains how to install it.
I hope this helps,
RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(5,282 Views)
thanks for the answer. Actually today we found the solution. Obviously we had some permission issues within our setup. When operating as Admin I could instal the NI-Serial on the RT.
Norman
(5,278 Views)
