NI-Farm Internal Error: Client received unexpected or bad data from the server.
When trying to compile received this message:
A communication error occurred.
DetailsError -123206 occurred at niFpgaCompileFarm_UploadFile.vi
Possible reason(s):
Complete call chain:     niFpgaCompileFarm_UploadFile.vi     niFpgaCompileWorker_UploadFile.vi     niFpgaCompile_Worker.vi:1
Do you know what could be a solution? Already tried to reinstall Xilinx11.5
Configuration:
Compiling on local compile serverCompilation Tool: Xilinx 11.5
Run when loaded to Fpga: FALSE
Xilinx Options---------------------------------------Design Strategy: BalancedSynthesis Optimization Goal: SpeedSynthesis Optimization Effort: NormalMap Overall Effort Level: HighPlace and Route Overall Effort Level: Standard
JobId: fqu2nOvWorking Directory: C:\NIFPGA\compilation\20110518_FPGATarget_AI1_61FE6EE8
Message 1 of 13
(6,592 Views)
first of all, please let me know if you can compile locally too or not.
If not, I have some questions to get a little more inside the problem:
1. What did you enter in the configure compile worker configurations window? (see screenshot)
2. Which versions of LabVIEW FPGA and LabVIEW do you use?
3. Which OS?
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
Message 2 of 13
(6,564 Views)
Hi Suse,
no, I cannot compile locally
1. Compile worker window is exactly as in your screenshot
2. Labview 2010 (version 10.0f2) and LabVIEW 2010 FPGA (version 10.0.0)
3. Windows 7 Professional, 32 bit
Best,
Artem
Message 3 of 13
(6,560 Views)
Hi Artem,
Can you try to start the compile worker manually? Start>Programms>National Instruments>FPGA>Compile Worker and then Compile it again in the lvproj.
Christian
Message 4 of 13
(6,500 Views)
Yes, I can start, but no, I cannot compile
Message 5 of 13
(6,480 Views)
Does this happen just with a specific lvproj, or a specific vi, or does this error also come up with a new project and a new vi to compile?
Christian
Message 6 of 13
(6,437 Views)
no, this is general. I cannot compile any FPGA vi
Message 7 of 13
(6,432 Views)
It really seems that there is something wrong with your installation of LV FPGA. Can you try to repair LV FPGA.
Christian
Message 8 of 13
(6,426 Views)
When trying to compile the FPGA target I get an error. NI Farm: farm server is not responding ( error 123011).
I installed another version of xilinx (12.3, the system was using 10.1 version), but it still uses the old version.
I reinstalled LabVIEW FPGA, still nothing.
I am using LabVIEW 2010 SP1, LabVIEW 2010 SP1 FPGA, NI RIO 3.6.0, and hardware: NI CompactRIO 9004, chassis NI 9102, and module NI 9229.
The operating system is Win XP.
Can somebody help me, please? It is urgent.
Dana
Message 9 of 13
(6,140 Views)
Accepted by Artem Mishchenko
Actually, I upgraded labview (to LabVIEW 2011), labview FPGA (2011), xilinx compile tools and NI-RIO dirvers to the latest versions (by August 2011). Now everithing is working perfectly!
Message 10 of 13
(6,138 Views)
