10-29-2009 09:41 AM
I have the 9870 rs232 serial module on a cRIO 9073 chassis. I have looked at the serial loopback example, added to my project, changed the input node to point to the right serial port. This works fine when I use a loopback connected to the serial port cable.
However, when I connect the port to the serial port at the back of my pc (using female to female serial cable) and run the 'Serial Loopback DMA Rd (Host).vi' I cannot see any data sent on hyperterminal monitoring the com port of my PC. Also if I type any characters on hyper terminal I cannot see them being received by the LabView program.
Why is this happening? i.e. the example working well with a loopback adapter and not when connected to another serial port?
All help will be appreciated.
regards
Harshil
Solved! Go to Solution.
10-30-2009 08:33 AM
Do you have any details on the cable you are using? You may need a null modem cable.
Do all the settings in hyperterminal match the cRIO? I.E: Baud rate/parity/start and stop bits etc
Could you take a screenshot of the hyperterminal settings and also the windows serial port settings? Could you attach your cRIO VI?
Many Thanks,
10-30-2009 09:35 AM
I have checked, and all my settings match the ones on the cRIO.
The cable I am using is standard (female to female) cable. I have given the link for it below.
I will try and use a null modem cable.
Also, I have attached the screenshots as requested.
Thanks for the help.
Harshil.
10-30-2009 09:36 AM
11-04-2009 04:09 AM
Thanks for the help. Null modem cable did the job.
Regards
Harshil.
09-21-2010 01:01 AM
Hello Mark,
I have connected NI 9870 on cRIO 9073.
Chroma power supply is connected to port 2 of NI 9870.
I am trying to communicate with it using DMA FIFOs.
I am able to send/write command to it like switching power supply replay ON and OFF.
But when I try to read from command *IDN?\n I get blank response.(only spaces) ![]()
do you have any idea what could be missing?
Any help is appreciated.
Thanks.
10-24-2011 12:31 PM
Hey Harshil,
I am trying to use the similar program, i guess its not working for me. I just want to write a string to the serial port. I have the example setup, no errors, but output either on computer or scope.
Can you please post the exmaple and also you talked about the loopback adapter, what is that? I think i may be missing some thing here.
I will greatly appreciate that.
Ajay
