NI 9212 Can't be identified in the NI9144
HW Environment : NI 9067 NI9144 NI9212
SW Environment : NI LabVIEW2015 SP1  EtherCat15.0 The Lasted Firware Version
Question:NI 9212 Can't be identified in the NI9144,The system says:This C series modules is not surpported by the current version NI-Industrial Communications for EtherCat
(2,701 Views)
Have you tried to re-download the 9144 firmware? Seems like the 9144 firmware is corrupted for some reasons.
If the problem still exists, can you please try to power off the 9144 for several minutes? Please also check if you have followed the "Electromagnetic Compatibility Guidelines" on page 3 of the 9144 user manual.
(2,687 Views)
I only have updated the fareware of crio9067
where I can change the fareware of 9144?
I Can't find the exact UI for this change during in MAX?
(2,677 Views)
You can find the detailed instructions on page 11 of the NI 9144 user manual.
(2,673 Views)
