NI 9149 - Cannot Connect via Ethernet
We have an NI 9149, and we cannot connect in NI-Max - Remote Systems.
However, I CAN ping the device name when you connect the device via USB to a PC. You can use the same address to ssh, but the default name/password does NOT work.
Can you reset to factory defaults without being able to connect via NI-Max?
(1,218 Views)
Hi Chris.
In regards to the network issue, i'd recommend an IP reset (setting the network settings to DHCP/Link-local) Verify the System IP Configuration - NI.
With the lost password, you should probably request a .cfg file from NI to reset the device. There are a few of these floating around on the forums, however, I know from experience that there are different versions depending on the device you're using, so I'd recommend talking to NI in order to get the correct one.
Kind regards
LabVIEW Fairy
cRIO Enthusiast
Please mark solutions when appropriate.
(1,179 Views)
