Missing Dependency in deployment to cRIO
I have inherited a complex project from a former intern, and am attempting to revive the project. All was well this morning as I ran his VIs, but eventual trouble has left the system in a perplexing state.  I am no longer able to deploy most - but not all - VIs and project items to the RT system ( a cRIO).  In fact, I can no longer deploy the cRIO 9114 chassis itself or any of the modules therein, but I receive the following message:
Labview: (Hex 0x80DF0010) There is a missing dependency in the current deployment.
No further information is obviously available regarding what, exactly, is missing.  It was working this morning, but after a Labview crash, I now get this error.  Restarting everything, etc, was of no avail.  I am guessing that something has been corrupted and kindly saved that way by Labview.  Any ideas as to how to find the problem and repair it?
(3,156 Views)
Hi womack,
Try reformating and reinstalling all the software on the cRIO.   To reformat, the cRIO will need to be in safe mode.   Once you put the cRIO in safe mode, you can right-click on it in MAX and select Format Disk
Then just reinstall of the software.  This KB shows you how to do that.
Hope this helps!
Starla T.
(3,144 Views)
