LabVIEW Real-Time Control (NI-DAQmx) Sample Project?
Looking for LabVIEW Real-Time Control (NI-DAQmx) code example but it does not come up in my example finder. I have real-time and daqmx installed.
Thanks, J.
(2,345 Views)
Are you following the steps in Take Your First Measurement in LabVIEW Real-Time but couldn't find the shipping examples at C:\Program Files (x86)\National Instruments\LabVIEW <xxxx>\examples\DAQmx path?
https://tmesystems.net/
(2,319 Views)
Seem to be missing that folder. DAQmx is installed. Should I try reinstalling or repairing my install?
(2,310 Views)
For LabVIEW 2023 or later, the examples for DAQmx are at a different location
C:\Program Files\NI\LVAddons\nidaqmx\1\examples\DAQmx\Analog Input\
(2,307 Views)
Still not there
When I try to add a target all I get is this and not the full list of targets. Is this indicative of messed up installation?
(2,302 Views)
Check your 32-bit folder,
C:\Program Files(x86)\NI\LVAddons\nidaqmx\1\examples\DAQmx\Analog Input\
If they are not found in the 32-bit folder as well, that indicates that you have not installed the LabVIEW 2023 Support for DAQmx. It might happen if you install LabVIEW after installing the driver. Run the installer for the DAQmx driver again to install the missing file.
You cannot add a cRIO under My Computer. Right-click on the Project to add a cRIO target.
(2,293 Views)
