取消
显示结果
搜索替代
您的意思是:
LabVIEW Real-Time Control (NI-DAQmx) Sample Project?
Looking for LabVIEW Real-Time Control (NI-DAQmx) code example but it does not come up in my example finder. I have real-time and daqmx installed.
Thanks, J.
0 项奖励
1 条消息(共 6 条)
2,256 次查看
Are you following the steps in Take Your First Measurement in LabVIEW Real-Time but couldn't find the shipping examples at C:\Program Files (x86)\National Instruments\LabVIEW <xxxx>\examples\DAQmx path?
https://tmesystems.net/
0 项奖励
2 条消息(共 6 条)
2,230 次查看
Seem to be missing that folder. DAQmx is installed. Should I try reinstalling or repairing my install?
0 项奖励
3 条消息(共 6 条)
2,221 次查看
For LabVIEW 2023 or later, the examples for DAQmx are at a different location
C:\Program Files\NI\LVAddons\nidaqmx\1\examples\DAQmx\Analog Input\
0 项奖励
4 条消息(共 6 条)
2,218 次查看
Still not there
When I try to add a target all I get is this and not the full list of targets. Is this indicative of messed up installation?
0 项奖励
5 条消息(共 6 条)
2,213 次查看
Check your 32-bit folder,
C:\Program Files(x86)\NI\LVAddons\nidaqmx\1\examples\DAQmx\Analog Input\
If they are not found in the 32-bit folder as well, that indicates that you have not installed the LabVIEW 2023 Support for DAQmx. It might happen if you install LabVIEW after installing the driver. Run the installer for the DAQmx driver again to install the missing file.
You cannot add a cRIO under My Computer. Right-click on the Project to add a cRIO target.
0 项奖励
6 条消息(共 6 条)
2,204 次查看
