IP Integration node input port data type as an array
Can I have an input port as an array of std_logic_vector in an IP integration node?
I have this in my vhdl code:
type array_std_logic_vectors is Array (31 downto 0) of std_logic_vector (15 downto 0);
entity top is
Port (
      Clk_i             : in STD_LOGIC;
      Cmd_data_i   : in array_std_logic_vectors;
I am getting this error when I try to configure the IP block
Port "Cmd_data_i" with type "array_std_logic_vectors" has an invalid data type. The IP Integration Node supports only the std_logic and std_logic_vector data types. Refer to the LabVIEW Help for information about converting ports to these data types.
Is there anyway to make this work?
(6,584 Views)
Hi SMO33,
As it says in the error message, the LabVIEW FPGA IP Integration Node supports only the std_logic and std_logic_vector data types for top-level VHDL files. See this KnowledgeBase article for information on converting VHDL data types for use with the IP Integration Node.
David B.
(6,550 Views)
I have read this article. It does show how to convert from one type to another but it doesn't show how you can do an array of std_logic_vector input.
Any idea how to work around this?
(6,545 Views)
Make 32 inputs of std_logic_vector(15 downto 0)?
Make 16 inputs of std_logic_vector(31 downto 0) and massage the data in the VHDL, basically transpose.
Make 1 input of std_logic_vector(511 downto 0) and flatten the array as input?
etc...
(6,529 Views)
Making dicsrete inputs for the array is not practical especially I might need to increase the array size to 512.
LabView FPGA only supports maximum size of 64  std_logic_vector(63 downto 0)
(6,520 Views)
Hi SMO33,
Unfortunately, you are not able to do an array of std_logic_vector. The workaround is what WillD is discussing in his post.
David B.
(6,503 Views)
