‎09-01-2013 10:44 PM - edited ‎09-01-2013 10:45 PM
Can I have an input port as an array of std_logic_vector in an IP integration node?
I have this in my vhdl code:
type array_std_logic_vectors is Array (31 downto 0) of std_logic_vector (15 downto 0);
entity top is
Port (
Clk_i : in STD_LOGIC;
Cmd_data_i : in array_std_logic_vectors;
I am getting this error when I try to configure the IP block
Port "Cmd_data_i" with type "array_std_logic_vectors" has an invalid data type. The IP Integration Node supports only the std_logic and std_logic_vector data types. Refer to the LabVIEW Help for information about converting ports to these data types.
Is there anyway to make this work?
‎09-03-2013 08:50 PM
Hi SMO33,
As it says in the error message, the LabVIEW FPGA IP Integration Node supports only the std_logic and std_logic_vector data types for top-level VHDL files. See this KnowledgeBase article for information on converting VHDL data types for use with the IP Integration Node.
‎09-03-2013 09:00 PM
I have read this article. It does show how to convert from one type to another but it doesn't show how you can do an array of std_logic_vector input.
Any idea how to work around this?
‎09-04-2013 07:53 AM
Make 32 inputs of std_logic_vector(15 downto 0)?
Make 16 inputs of std_logic_vector(31 downto 0) and massage the data in the VHDL, basically transpose.
Make 1 input of std_logic_vector(511 downto 0) and flatten the array as input?
etc...
‎09-04-2013 12:38 PM
Making dicsrete inputs for the array is not practical especially I might need to increase the array size to 512.
LabView FPGA only supports maximum size of 64 std_logic_vector(63 downto 0)
‎09-05-2013 06:40 AM
Hi SMO33,
Unfortunately, you are not able to do an array of std_logic_vector. The workaround is what WillD is discussing in his post.
