How to store counter values running on cRIO?
Hello everyone.
I am reading digital input pulses from NI-9411 (used for Flow sensor, it reads digital pule from sensor),
  • FPGA.vi runs on 40MHz,
  • Couter reset at every 1 second. in FPGA.vi (Max pulse rate from Flow sensor 150 Hz
In HOST:vi how to store this valuses in a array. I used seperate timed loop with 1kHz and array size with 150 (N).
I need Max counter value per second.
Array Max and Min vi not suppoetred in FPGA.vi, so i have to count in host.vi.
i am attaching screen shot of my FPGA and Host code.
Wating for your reply
Tejas
(4,662 Views)
Hi Tejaskumar,
the easiest way to store values in an array is the built array function or autoarray with a for loop.
Or do I understand anything wrong?
regards
Tobias
(4,540 Views)
Hi Mr_Tejaskumar,
I just wanted to ask what hardware you used for the pulse readings (NI-9411) for a flow sensor.
Did you need to get the d sub connector kit?
cheers,
will
(4,294 Views)
Hello Will,
We was using BR 473 (150Hz) Flow sensor.
Regard´s,
TejasKumar
(4,289 Views)
