FPGA simulated I/O Recive error -61399
I'm trying to simulate a cRIO-9073 on my development computer. I want to use the simulated I/0 features. If I use the random data, I have no problem to run my simulated VI. If I use the "Use Custom VI for FPGA I/O" option, I always get the error -61399.
I already had a look at this Link but and use a template VI but it doesn't change anything. I also had a look at the tutorial explaining how to do it but with no luck...
Any idea?
Thanks!
(4,351 Views)
Accepted by vgravel
Hi vgravel,
Did you also that the " Custom VI has been configured for every I/O item that you are using in your FPGA code"?
FLash
Applications Engineer
(4,332 Views)
Oops... that was indeed the problem...
Sorry about that and thanks for the help!
Vincent
(4,310 Views)
I have a same problem. I tried to do according to the instructions stated above.
http://zone.ni.com/reference/en-XX/help/371599D-01/lvfpgaconcepts/test_bench_tutorial/
My FPGA project has only 2 I/O that would be AI0 and AO0.
What I need to do is add data earlier acquired  by DAQ card for testing  purpose.
What I did  create a new VI from  Template. I have modified:
In "Running" case of Execution Stage...
1)Duplicated the case in I/O case structure. Named it Input.
2) Did the same thing for Node or Element Type Case. Named it Read I/O.
3)Removed the Report suppor (connected tunels)
4/5/6  same steps as in 1 2 3 just naded Output and Write I/O.
7) In Read I added Random number and afterwards build array (just for testing purpose)
😎 In Write -- I did nothing. I just don't get it why do I need to make a local variable in this case. (I did create it but) haven't used it.
If U don't mind please give me a hint here. I would like to run a simulation as soon as possible and finish my degree ;/. What did U mean by  " Custom VI has been configured for every I/O item that you are using in your FPGA code"?. Thougth it was done by setting up cases ;/.
Print screens:
(3,622 Views)
Think I know what was done wrong.
Input Output names should has the same name as the I/O staded in project explorer.
I just renamed the case names to the names of the connectors. Think it works. Now I just need to add the data. Regards.
(3,617 Views)
