02-09-2023 03:59 AM - edited 02-09-2023 04:14 AM
Hello, I hope everyone is healthy and well. I am a beginner in designing measurement systems. I am trying to measure the pressure, temperature and flow of a liquid that is flowing through a pipeline. There will be a pump in the circuit and maximum pressure in system will be 15 bar.
I am using Honeywell MIP Series Pressure Transducer has a linear relationship between measured pressure and output voltage. The output voltage of sensor is between 0.5V and 4.5V. This sensor must be excited by 5V. Since I need to read the voltage measurement, I am planning to use NI-9201. Does this voltage input module have a capability of exciting the specified pressure transducer?
Best Regards.
Solved! Go to Solution.
02-09-2023 02:55 PM
I've ony done a quick look, so do check to confirm before doing anything:
02-14-2023 01:22 AM
Hello Sir,
Thanks a lot for clarification.
Best Regards.
Jiyan Baran Bukun
