12-06-2018 12:53 PM
Which link are you referring to?
12-06-2018 01:23 PM
I am referring to this link in the attachments ModuleProgrammingModes.zip:
I have a similar problem. As soon as I deploy my Real-Time (9045), the card on Slot2 (of the 9045) Program Mode switches back to Real-Time Scan (IO Variables), no matter what I saved on NI-MAX, no matter what card is on slot2.
My systems has a 9045 Chassis, with a 9145 etherCAT extension chassis.
To find out the cause, I created a new project and started adding items. The cause is the C module 9381 on the 9145 chassis. Once I add this module on slot 2 of the extension chassis, then slot 2 on the 9045 chassis becomes the issue I just described.
Regarding the solution, I could not download the link in the article above.
Also, when I try to use cRIO System Configuration, I get an error saying the hardware is not supported.
Thank you
12-10-2018 01:14 PM
I found another trigger that causes the problem.
In LabView my project, I need to configure the 9401 card to be an output instead of input, once I deploy to the chassis, Slot 2 (of the 9045) Program Mode switches back to Real-Time Scan (IO Variables).
Still hoping for a solution.
12-10-2018 01:42 PM
In case it helps, this is the code I put in to initialise my modules to fpga mode at the beginning of my RT code.
12-17-2018 11:58 AM
stuartparkinson thank you for the code. It worked perfectly!
12-28-2018 10:04 PM
I believe the issue is already fixed in CompactRIO 18.5:
