CompactRIO Modules
Hi, is there a module for CompactRIO to measure current up to 100mA? I only find modules for currents in a range of -20 to 20 mA. I need it for an automotive solution where the switch I need to measure, consumes 90 to 100 mA.
(1,045 Views)
Accepted by JMBstrd
The next available range is 5Arms, below are the available modules
if you're very particular about the 100mA range, you can use a differential voltage input module and use an external current shunt resistor to measure current.
Santhosh
Soliton Technologies
(1,001 Views)
