Can you run two or more parallel loops using LabVIEW FPGA?
I just want to know if you can run two or more parallel loops (HOST) using LabVIEW FPGA? Can I use LabVIEW Real-Time instead?
(4,077 Views)
When programming FPGA applications, you will have 2 VIs - one host and one FPGA. The FPGA VI runs on the FPGA target, and your host VI will run either on a Real Time system (e.g.. RIO Real Time controller) or a host computer. To answer your question though, yes you can have parallel loops in your host VI as well as the FPGA VI. There is no constraint there.
Kareem W.
Web Product Manager
(4,069 Views)
Thanks, I appreciate the information!
(4,064 Views)
