11-03-2011 06:13 PM
I just want to know if you can run two or more parallel loops (HOST) using LabVIEW FPGA? Can I use LabVIEW Real-Time instead?
11-04-2011 08:06 AM
When programming FPGA applications, you will have 2 VIs - one host and one FPGA. The FPGA VI runs on the FPGA target, and your host VI will run either on a Real Time system (e.g.. RIO Real Time controller) or a host computer. To answer your question though, yes you can have parallel loops in your host VI as well as the FPGA VI. There is no constraint there.
11-04-2011 09:08 AM
Thanks, I appreciate the information!
