08-25-2009 12:15 PM
Solved! Go to Solution.
08-25-2009 12:46 PM
What version of NI-RIO are you using? If you haven't do so, install the latest version of NI-RIO. And, if you have, I would recommend reinstalling it.
08-25-2009 01:29 PM
08-25-2009 02:09 PM
08-25-2009 03:29 PM
08-25-2009 05:08 PM
08-26-2009 07:58 AM
Yes, but just to be clear, the RT module would not install, so I was looking for a seperate RT module for the cRIO because the installation instructions were referring to one under an embedded folder.
The real problem, solved now, is the RT module would not install until I manually uninstalled the old NI Serial and then installed the new one with LabVIEW 2009. During the first attempt to install LabVIEW 2009, the package configuator detected the old NI Serial and told me that it could not install the new NI Serial until I uninstalled the old, but gave me the option to defer this step, which I did.
Thank you for your help.
