CVI RT read from FPGA DMA FIFO Speeds
Just out of curiosity, have you tried implementing the read by just polling an indicator from the FPGA rather than DMA'ing it? If you only need the most recent value, it doesn't make sense to construct a DMA, and that should reduce your read time.
Message 11 of 12
(2,335 Views)
Yes, but I'm not sure what mechanism it uses to read/write to those indicators.  Doesn't that use DMA as well?
Message 12 of 12
(2,328 Views)
