Build and Compile a package on RoboRio. PLEASE HELP
Hi everyone,
I'm pretty new to this but after hours and days of researching and seeking for help from professors at my school, I came here and hope to get some help.
I'm using a roboRio and trying to use Aruco marker for the vision. However that requires to manually install and build the opencv-contrib package on the roboRIO (https://github.com/opencv/opencv_contrib). I was looking up ways to do this but since the Linux system for roboRIO is NI Real-time Linux, the procedure seems different. I tried ./configure in the unzipped opencv-contrib tar folder I downloaded but it told me command not found. Please let me know how I can approach this, what I need to download in order to build this package.
Thanks a lot!!!
(2,194 Views)
This White Paper contains information regarding how to use OpenCV with NI Vision: https://www.ni.com/en/support/documentation/supplemental/16/developing-vision-applications-using-ope....
The procedure is a bit different like you mentioned.
Marco C.
Applications Engineering
(2,166 Views)
