Acquiring data from FPGA and write them to a file
Hi everybody,
I am quite new to labview and appreciate your insights on the following questions:
I need to acquire analog data from NI 9205 and digital data from NI 9401, and then write them to a friendly file for further analysis in MATLAB and also recall them for my control program
After a little exploring here and getting some suggestions, I decided to use DMA FIFO. I've attached the screenshot of the FPGA file and the PC host file here.
1- Is this a correct way of reading and writing the file?
2- Is it correct to use the "write to measurement file" inside the timed loop?
3- I saw a post on this forum (see here )where the poster used a fancy method using consumer-producer structure. Is that necessary or I can get away without using queue functions? By the way, I need to recall these data in the main VI where I need them for controlling purpose. (Position control)
So, I do not know how to recall these data.
4- Are the chosen values for "Depth" and "Timeout(ms)" fine? 24000 and 0 respectively.
Overwhelmed Morris
P.S: I am using LabVIEW 8.6.
(9,399 Views)
I am attaching the codes as well.
By the way, how should I decide about the number of elements(points) to read) and the FPGA period?
Morris
(9,397 Views)
Hi Moris,
Check out the Logging Data to Disk tutorial in the Getting Started with CompactRIO series.
The FPGA section walks through creating a simple logging application from scratch.
(9,371 Views)
Hello 😃
So ima LabView noobie i got to this forum originally from the first one you started...
Hopefully im in the right place...
I went ahead and linked my design im working with and ultimately want to save and store data to:
1. an onboard memory device (there is a onboard SD im thinking would work)
2. being able to upload from the FPGA deice to a server (for testing purposes this server will be on the home network)
3. being able to access the FPGA saved files at any time from the server.
Like i said im a noobie and and been searching religiously for some direction...
Dont get me wrong im not looking for hand outs,  just need to be pointed in the right direction... 😃
i followed the link you posted on how to "create a simple logging application from scratch" but noticing the date on this thread... i think it might be a little out of date =(
The RIO board im working with is a sbRIO9636 and while trying to follow the steps on the tutorial... there is a large unexplained gap between step 2 and step 3: Select the Appropriate Programming Model... they want me to use a Scan Interface but im not seeing the pop up window it is showing in the tutorial nor does it explain how to manually set it =((
Any and all insight is welcomed, for any knowage to me right now is a step forward in the right direction...
Also i do not mind elaborating on my circuit if needed... just didnt want to flood this thread with a bunch of nonsence if there is a better place to be asking =P
(8,250 Views)
I am a new user to Labview and I have a question about acquiring data in FPGA mode. I have a compact CRIO 9024, 2 ni 9237 and one 9401 all configured according to the attachements. I tried a lot to take a reading using FPGA interface but I could not. I guess I do not program correctly. I just want to take very simple reading to make sure my sensor are working. As it is seen the indicator shows a zero value for every sensor I checked as if it is not working. I did not use any loop or something. This is a very simple thing. I would be grateful if somebody let me know how to write a very simple program to take my reading. I am sorry if my question looks very wierd to you in advance.
(7,989 Views)
First of all, you should have started a new thread.
1) You need to use a loop so that you constantly read the line.  Also be sure to put a wait in the loop to time how often you take the sample.
2) You are trying to interface with a cRIO.  When dealing with the cRIO, your FPGA has to communicate with your RealTime OS.  There should be a cRIO project template in there for you to play with.
GCentral
(7,984 Views)
