Accelerometer and cRIO module NI9232
I have a NI9232 module in my cRIO setup and I would like to measure vibration with an accelerometer. Can I forexample use a Wilcoxon Research model ED-786A (teds support) and connect it directly to the module with IEPE exitation activated? Or do I need an external power source in addtion?
Christian
(6,643 Views)
Thanks for your question,
Yes - the 9232 provides IEPE, which is turned on with a I/O node method or property in LabVIEW FPGA.
You may be interested in these links to help you get up and running:
https://forums.ni.com/t5/Example-Code/Embedded-High-Speed-Data-Logger-Reference-Design/ta-p/3996474 - a vibration data logger reference design
https://www.ni.com/en/support/documentation/supplemental/09/ni-compactrio-waveform-reference-library... - the underlying waveform acquisition reference library used by the data logger.
Let us know how else we can help.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(6,639 Views)
Ok, so no external power supply will be needed?
the NI9232 can provide the following?
Constant Power supply IB
4 mA
Min. 2 mA / Max. 10 mA
polarised untill
Voltage supply UB
+ 24 V
Min.+ 18 VDC/ Max.+ 30 VDC
(6,583 Views)
