Accelerometer and cRIO module NI9232
I have a NI9232 module in my cRIO setup and I would like to measure vibration with an accelerometer. Can I forexample use a Wilcoxon Research model ED-786A (teds support) and connect it directly to the module with IEPE exitation activated? Or do I need an external power source in addtion?
Christian
(6,505 Views)
Thanks for your question,
Yes - the 9232 provides IEPE, which is turned on with a I/O node method or property in LabVIEW FPGA.
You may be interested in these links to help you get up and running:
http://zone.ni.com/devzone/cda/epd/p/id/6388 - a vibration data logger reference design
http://zone.ni.com/devzone/cda/epd/p/id/6206 - the underlying waveform acquisition reference library used by the data logger.
Let us know how else we can help.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(6,501 Views)
Ok, so no external power supply will be needed?
the NI9232 can provide the following?
Constant Power supply IB
4 mA
Min. 2 mA / Max. 10 mA
polarised untill
Voltage supply UB
+ 24 V
Min.+ 18 VDC/ Max.+ 30 VDC
(6,445 Views)
