RF Measurement Devices
frequency modulation multisim
Where can I find examples on basic FM circuits. Specifically, interpeting the spectrum analyzer given a set of input values.
(11,662 Views)
Hi Tacx2x2,
Can you elaborate on what you are looking for? I don't understand exactly what you are asking.
Andy Hinde
RF Staff PSE
(11,656 Views)
Hi Andy,
     thanks for the response. The trouble I'm having is givena circuit with conditions I have to input, I set the spectrum anaylzer to the values that are given and run the simulation and it produces an output of a spectral plot. When i measure the values of the spectral plot, they do not match up to the Bessel table with a given modulation index of 5.  here is the a list of what goes into the diagram
Spectrum analyzer
o-scope
FM generator
for the O-scope settings, Time base scale =20us/Div
                                         Xpos = 0
                                         Y/T
             Ch A     scale =1v/Div Ypos=0, DC,  Trigger (Pos Edge, level=0)
 Spectrum Analyzer        Freq (Center=100kHz,  span=200kHz)
                                   Amplitude (lin, range =0.1 V/Div),
                                    Resolution = 400Hz
  Is there a certian way to read the ouput plot on the Spectrum analyzer?
Tim
(11,655 Views)
 Hi Tim,
 Could you please elaborate a bit more on how your system is setup there:
   1. Do you have NI hardware in this system?
   2. Are you using any NI software (LabVIEW, LabWindows, etc)?
   3. Is the system you've described entirely simulated?
   4. Could you take a screenshot of your system and post it here?
 In answer your original question, where are RF resources?
 I would like to point you to this DevZone article, RF and Communications Fundamentals.
 I hope this helps,
 Have a great afternoon.
 MatthewW
(11,638 Views)
Using Multisim.Not sure if you read what I wrote previously to Andy but it has all the system parameters
tim
(11,628 Views)
Hi tacx2x2:
This document might help you: Understanding RF with NI Multisim
If you have Multisim specific questions, please post your message here:
Fernando D.
NI
Fernando D.
(11,608 Views)
