RF Measurement Devices
RFSA sample VIs
Hello, I have developed an RFID reader transmitter with the following parameters:
• Modulation Scheme – DSB-ASK
• Encoding Scheme - PIE
• Carrier Freq. – 915 MHz
• RFSG Tx Power Level – 0 dBm
• Tx Channel Bandwidth – 500 kHz
Could you suggest any existing RFSA vi that will be able to check if my transmitter is properly working? Thank you.
(6,508 Views)
The best LabVIEW shipping example that we offer for that application would be MT niRFSA ASK Demod.vi from the LabVIEW Example Finder ( LabVIEW » Help » Find Examples » Hardware Input and Output » Modular Instruments » NI-RFSA » Modulation Toolkit ).
This example shows demodulation of an ASK signal using devices programmed using the niRFSA driver.
There is also an article online, Advanced RFID Measurements: Basic Theory to Protocol Conformance Test, which discusses RFID measurements.
There is not a DSB-ASK-specific example already written (that ships with LabVIEW or online to my knowledge). Given the above example and article, this should get you started in the right direction in creating a VI to test your transmitter.
Aaron
(6,497 Views)
Thank you! I was already able to demodulate my signal. I have another question. Is it possible in NI to display the waveform of an RF signal? Thank you!
(6,484 Views)
Margarette,
You can easily display a waveform using LabVIEW. In the Example Finder, as I mentioned above, several of the RF examples display a spectrum (or other waveform signals) using waveform graphs and charts. The RFSA Demo Panel.vi is a good starting point. I would encourage you to look at those. Also, you can use the RFSA Soft Front Panel (Programs » National Instruments » NI-RFSA) installed with NI-RFSA to use the analyzer in a non-programming environment.
Aaron
(6,474 Views)
I'm working on getting this for a Gen2 RFID as well.  Can you share how you made your DSB-ASK waveform in LabVIEW?    I also want to find/create a solution for PR-ASK.
(1,072 Views)
