10-23-2013 10:28 AM
It's really handy to use the Ctrl-Space, Ctrl-D shortcut to create indicators on loop tunnels (and shift registers). Take this code for example:
I can select the For Loop, and very quickly create indicators for the error, style array, and label array by pressing Ctrl-Space, Ctrl-D:
But notice that it also creates a control for the "N" terminal of the loop. I *always* end up deleting this terminal right after it's created.
So the question is, should Ctrl-D on a For Loop ignore the "N" terminal? Here are the potential changes I can think of to make in LabVIEW 2014 to address this issue:
Option (3) is the safest option to satisfy all use cases, but also the least discoverable. Let me know what y'all think.
10-23-2013 10:30 AM
Screw safety, this is a development tool that has no impact on previously existing code. Option 2 all the way!
10-23-2013 10:33 AM
Could you detect if an input tunnel is autoindexing? If so, only create a control for the N if a autoindexed input tunnel is not detected. I guess you could call that option 4.
If that isn't possible, I say you have more important things to do, so option 1.
10-23-2013 10:36 AM
While you're fixing the loops with Ctrl+D, can you make it work with just the tunnels selected? That might make changes to the "N" unnecessary. I've tried numerous times to select a tunnel on the loop and Ctrl+Space Ctrl+D with no results
10-23-2013 10:44 AM
I have more important things to do than improve the usability of productivity features in LabVIEW that I also happen to use every day? ![]()
I do like option 4, and I don't think it would be that hard to do.
Yeah, Ctrl-D doesn't look at tunnels today. I guess it could. It should be fairly easy for me to add support for the outer (source) terminals of all tunnels...and maybe shift registers too.
10-23-2013 10:49 AM
Hey, we need some way to slow you down. How else can one of us finally catch you?
The more I think about it, the more I like my option 4. The only time I use the N is when I am not autoindexing an input. So it makes complete sense.
10-23-2013 12:59 PM
If you get the tunnels working, I'd be happy to alpha test it for you ![]()
10-23-2013 02:18 PM
Ok, alpha testers, here you go. Copy this VI to your LabVIEW 2013\resource\dialog\QuickDrop\plugins folder (backup the VI that is already there in case I screwed something up). This update to the Wire All Terminals shortcut implements the following functionality:
Let me know what y'all think!
10-23-2013 02:23 PM
Quick initial testing looks good. Will continue to play with it though.
10-23-2013 02:42 PM
Looks good! no issues thus far. Thanks Darren!
