Python and NI
Issue with nixnet python driver
Hi everyone,
I'm trying to make a simple Python script to log CAN frames using NI-XNET driver and a USB-8502 CAN module.
I wrote a some code to display all the CAN frames transiting on the bus.
import nixnet
from nixnet import system
from nixnet import constants
from nixnet import types
import time
# Get CAN interface name
can_interfaces = nixnet.system.System().intf_refs_can
can_list = []
for can_interface in can_interfaces:
    can_list.append(can_interface)
can_interface = can_list[0]
print(can_interface)
can_database = ':can_fd_brs:'
can_cluster = ''
with nixnet.FrameInStreamSession(str(can_interface), str(can_database), str(can_cluster)) as input_session:
    input_session.intf.can_term = constants.CanTerm.OFF
    input_session.intf.baud_rate = 1000000
    input_session.intf.can_fd_baud_rate = 4000000
    input_session.start()
    for i in range(0, 10):
        frames = input_session.frames.read(10000, constants.TIMEOUT_NONE)
        for frame in frames:
            print(frame)
        time.sleep(0.1)
When I execute this code, I have the following error :
Traceback (most recent call last):
  File "D:\my_path\main.py", line 27, in <module>
  File "D:\Programs\Python\Python39\lib\site-packages\nixnet\_session\base.py", line 165, in start
    _funcs.nx_start(self._handle, scope)
  File "D:\Programs\Python\Python39\lib\site-packages\nixnet\_funcs.py", line 395, in nx_start
    _errors.check_for_error(result.value)
  File "D:\Programs\Python\Python39\lib\site-packages\nixnet\_errors.py", line 18, in check_for_error
    status = status_to_string(error_code)
  File "D:\Programs\Python\Python39\lib\site-packages\nixnet\_errors.py", line 33, in status_to_string
    status_string = buffer_ctypes.value.decode("ascii")
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe9 in position 31: ordinal not in range(128)
If I don't specify database and cluster in the FrameInStreamSession() call, I do not have error, but by default the configuration is CAN, not CAN FD + BRS.
Is this a known issue, and does anybody know how to solve this problem ?
I'm using Python 3.9.12 and nixnet 0.3.2.
Thanks to all for the support
Kind regards
(4,505 Views)
Always ensure that your hardware and network configurations are correct and that the nixnet library supports the CAN interface you are working with.
Here is the revised code:
from nixnet import system, constants, types
import time
can_interfaces = system.System().intf_refs_can
can_list = [can_interface for can_interface in can_interfaces]
# Ensure there is at least one CAN interface
if not can_list:
    raise Exception("No CAN interfaces found")
# Replace with actual database and cluster names
can_database = ':can_fd_brs:'  # Placeholder, replace with actual database
can_cluster = ''  # Placeholder, replace with actual cluster name
with system.FrameInStreamSession(str(can_interface), str(can_database), str(can_cluster)) as input_session:
    for _ in range(10):
            print(frame)
        time.sleep(0.1)
I really hope this helps!
(3,826 Views)
