Power Electronics Development Center
Webcast: New Open Source Testbed Platform for Smart Grid and Microgrid Research- Go from IEEE Paper to Working Prototype in Days
Join me live tomorrow at 11am Central for a live demonstration and webcast about a New Open Source Testbed Platform for Smart Grid and Microgrid Research (http://us.ni.com/smart-grid-webinar ).
New Open Source Testbed Platform for Smart Grid and Microgrid Research: Now Go from Paper to Prototype Deployment in Days
April 19th, 2017
11:00 AM – 12:00 PM
(GMT-06:00) Central Time (US & Canada)
To address the demanding needs of industry and university research groups pursuing critical innovations in Smart Grid and Microgrid technologies, National Instruments has joined forces with other industry leaders to create a new research testbed architecture.
Join us for an introduction and live demonstration of the new open source, commercially available platform spans from a low cost MyRIO Bidirectional Microgrid Inverter that enables students to form a desktop Microgrid, up to a full power 480 VAC, 100 kVA Semikron back-to-back inverter cabinet. A core element are new low voltage Semikron grid tied inverter cabinets with NI CompactRIO Ethernet TSN Sync Inverter control systems and embedded Opal-RT real-time digital twin HIL simulators.
Design teams now can go from a research paper to working, grid tied prototype in just days. Using open source reference design frameworks, new control algorithms are developed in a co-simulation environment and then rapidly deployed to physical hardware. Teams can move back and forth between deployment and simulation multiple times in a day, and easily compare measured and simulated results.
Virtual Reality 360 Photo
The testbed enables productive, risk free, team based development and testing of advanced intellectual property related to the following priority research areas:
1. Grid stabilizing bidirectional grid tied inverters and DC converter control systems
2. Distributed Energy Resources
3. Demand Response
4. Energy Storage Systems
5. Communication infrastructure and emerging network standards (IEEE 802.1 Time Sensitive Networking)
6. Multiple communication protocols (61850, DNP3, C37.118, Modbus)
7. Distribution Grid Management
8. Cyber Security, Private Communication, and Cyber Attack Resilience
9. Wide Array Situational Awareness
10. Phasor Measurement Units and Intelligent Electric Devices
11. Multi-Agent Distributed Control Schemes
12. Wireless communication and Software Defined Networks
13. Electric Transportation
14. GPS and Network-based Time Synchronization
15. Embedded Real-Time Digital Twins
16. Machine Learning (Deep Reinforcement Learning)
17. Real-Time Hardware-In-the-Loop (HIL) Simulation
18. Grid compliance and interoperability testing such as IEEE 1547 anti-islanding tests
19. Voltage and frequency and control loop stability analysis
20. Islanding, Reconnection and Sectionalizing
21. Resiliency, Fault Recovery, Self Healing
22. A/B comparison testing of new control schemes
23. Automated real-time test execution
24. Remote connection access
25. Data interoperability
Register Now: http://us.ni.com/smart-grid-webinar
Message 1 of 8
(11,965 Views)
Will video recording of the event be available online for viewing?
Message 2 of 8
(11,895 Views)
Yes, the recorded version of the webcast should be available within a week.
Meanwhile, please see the attached slide presentation from the webcast, which includes download links and also enhancements such as a comparison between physical and real-time simulation results using the Opal-RT EHS64 Embedded Digital Twin solver and the grid connected inverter.
Message 3 of 8
(11,883 Views)
The webcast recording is now live. Follow the link below to view. Please respond to this post with any comments or questions.
New Open Source Testbed Platform for Smart Grid and Microgrid Research: Now Go from Paper to Prototy...
Also, there is a new single click installer for the entire NI power electronics development toolchain which includes 45 days of evaluation mode support:
New Single Click Installer: NI Power Electronics Control Development Toolchain (18.2 GB, English)
Note: If you are running Windows 10, deselect "Xilinx Compile Tools for ISE 14.7" since it is not supported. These tools are only needed for the older sbRIO-9606 (PowerPC, Spartan-6) based General Purpose Inverter Controller (GPIC).
Message 4 of 8
(11,844 Views)
Excellent webcast Brian. Thank you for doing this. Definitely "a lot of information in a very short time".
I'm very curious about the TSN sync technology that you talked about. I will be digging deeper into this topic. I had implemented a similar grid-synchronization technique in my thesis that I completed last year, where I had used a GPS time-stamp for synchronization of 3-phase inverters. I had used a 9076 with a 9467 as time source.
Message 5 of 8
(11,833 Views)
Brian,
Can you point me to the latest co-simulation tutorial that is available online please?
Message 6 of 8
(11,709 Views)
You bet. The latest co-simulation tutorial project is here. You must unzip in a short path (like C:\LabVIEW 2016) or files will be broken due to the long paths created by Xilinx Coregen. You can also find recorded training workshops that go with this tutorial code here.
https://download.ni.com/evaluation/powerdev/training/FPGADNNLV2016.zip
Also some news related to machine learning. This project now also includes a new open source LabVIEW FPGA Deep Neural Network (DNN) Solver for fully connected Multi-Layer Perceptron (MLP) with ReLU activation.
Here is a screenshot of the LabVIEW FPGA code for a two layer DNN using the new solver. As you can see, the output of the top layer is the input to the layer below. There is also layer enable handshaking built in which provides the absolutely minimum latency. The top layer triggers the layer below to read it's first output on the FPGA clock tick immediately after it is written.
This is a resource optimized implementation designed to take a relatively small portion of FPGA resources so the rest of the FPGA is free for other application code. On the Zynq-7020 sbRIO-9607 GPIC, you can fit up to a 15 layer deep neural network. The goal for this FPGA DNN solver is to be as efficient as possible: use the minimum amount of FPGA resources while achieving the maximum theoretical performance for the resources used. The floating point FPGA code is fully pipelined, which means that every math operation (i.e. multiply, add, ReLU) is executing on every FPGA clock tick- no wasting time! Since each layer executes in parallel, there is no reduction in loop rate as more layers are added.
All machine learning tools must include an MNIST example, so here is a screenshot of the "required" MNIST example application running! The execution time is 7850 FPGA clock ticks per image (196 microseconds). If you want even faster, we now have a highly parallelized performance optimized DNN solver that takes just 3.5 microseconds per image (56 times faster).
Here is a screenshot of the performance optimized LabVIEW FPGA DNN solver running a 4 layer DNN with FPGA hardware acceleration. You can download the code here (you must unzip in a very short path like C:\LabVIEW 2016 or files will be broken). This project also includes bidirectional active front end (AFE) inverter control code for the new MyRIO Mycrogrid inverter boards.
A big advantage of the FPGA solvers is that they run in dedicated FPGA hardware. Therefore, the latency from physical input to-DNN-to physical output is extremely low, you can execute multiple DNNs in a true hardware parallel fashion, you can stream data in and out (using DMA or the new Host Memory Buffer) to keep the DNN crunching on every clock tick, the performance per watt is better than running on a GPU, etc.
Here is some notes on performance for a couple of typical applications.
Power electronics control application: You can execute an N layer DNN with 16 inputs, 100 neurons per layer, and 16 outputs at 25 kHz (40 microseconds.) Thus, the performance is sufficient for high bandwidth power electronics control. Loop rate execution speed does not depend on the number of layers. The number of layers is only limited by the number of DSP cores on the target (each layer consumes 9 DSP cores while a Zynq-7020 has 220 total DSP cores) and the amount of block RAM. There is about 4.8 Mbits of block RAM on a Zynq-7020, which is enough to hold about 150,000 weights and biases or roughly 6-layers with 158 neurons/layer.
DSA waveform analysis application (i.e. accelerometer vibration or electric power quality analysis): You can execute an N layer DNN with 8 inputs, 100 neurons per layer, and 8 outputs at 50 kHz (20 microseconds.) Thus the performance is high enough to perform advanced real-time analytics on every data sample! Also keep in mind that execution speed does not depend on the number of layers- only the execution rate of the slowest DNN layer. Loop rate performance (in 25 nanosecond FPGA clock ticks) for a layer is equal to the number of inputs * number of neurons, or in Hz it is f_loop = 40e6/(Num_inputs*Num_Neurons).
Because the DNN IP core is fully pipelined and takes advantage of the parallel distributed memory and DSP computing cores in the FPGA, the performance is quite excellent. Here is a benchmark comparison for various FPGA targets (in which all DSP cores are used) versus some GPU benchmarks I found online.
Please respond with any questions, comments or suggestions!
Message 7 of 8
(11,651 Views)
Thanks.
In the videos that you recorded I noticed a rather new way of using the multichannel VIs (eg LPF). In the screenshot below, I see that you have used the same LPF block at separate locations and simply providing corresponding channel numbers as constants. I am assuming these are "Multichannel LPF00 blocks" configured for "non re-entrant execution".
I have always been using such multichannel  subVIs within a for loop and passing indexed arrays of corresponding signals. Is this method, in effect, identical to the for-loop method in terms of FPGA resource usage and timing considerations? Do you have any tips/cautions in using this method in place of for-loop method?
I wasn't able to find an example VI in the latest GPIC Reference Design project for labview 2016 but I see you have posted the link for the codes here.
Do you have any documentation on the n-channel collector.vi that is used for graph plots in co-sim?
Message 8 of 8
(11,639 Views)
