Phase Matrix Products
QuickSyn Power Control
We have this two newly purchased  FSW-0020 synthesizers.
I was able to connect and control the device using my windows 10 laptop. I have successfully controlled the signal frequency using the quicksyn SFP V1.0.21, the spectrum analyzer shows the correct frequency entered in the front panel. However, the RF power output does not seem to change even if I adjust the "Synthesizer Power" either by adjusting the knob or entering the desired power level in the quicksyn software. It is stuck at around 10dBm. This is the case for both of the synthesizers. I am pretty sure that our spectrum analyzer is working well as it responds well with the benchtop Signal Generator that we have in the lab.
Spectrum AnalyzerSpectrum AnalyzerQuicksyn SFPQuicksyn SFP
(6,680 Views)
Accepted by mfdg
Looking at the FSW-0020 specifications it would appear that you need Option 2 in order to control the power output. Can you check whether you indeed have that option?
(6,608 Views)
Hello, do you have the Quicksyn SFP software ?
(1,990 Views)
