PXI
ubuntu drivers for PCI-6034E
I'm using a DAQ  (namely PCI-6034E) to acquire data from a force sensor ( ATI GAMMA); I'm doing this on ubuntu since I need to get these data on ROS.
To make ubuntu see the board i have to run the "nirlp" bash script to start up the drivers.
By the way this scripts get the kernel version that is currently "3.13.0-143-generic" and under the modules folder for this kernel I do not have the "natinst" directory that contains the kernel object "nirlpk.ko". By the way, this folder with the object is present in an older kernel module folder: "3.13.0-32-generic".
What should I do to make this thing work?
(2,350 Views)
Hi Pallo,
Ubuntu is a non-supported OS for our Linux drivers, so I recommend that you re-post this question in the Linux users section. I've attached a link to this section below.
https://forums.ni.com/t5/Linux-Users/gp-p/5097
Setu P.
Applications Engineering
(2,322 Views)
