From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
PXI
pxi-8513 smb connector
I want to use pxi-8513's front panel to trigger pxi-4080.
(1,135 Views)
Since PXI-4080 only supports PXI Triggers, either you can directly route triggers from 8513 over the PXI Triggers or wire up the 8513 front panel to SMB connector on PXI Controller then route the SMB connector to PXI trigger of PXI-4080.
Here is how to use the SMB connector on embedded Controller - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Uu6SAE&l=en-US
Santhosh
Soliton Technologies
(1,130 Views)
What should I do to route triggers from smb connectors  to backplane? I just have pxi-8513.
(1,116 Views)
