PXI
how to measure Grms
Hi, i am using a PXI-4472B card
i am trying to measure vibration from a table in Grms.
any examples?
thanks.
Ed
(3,585 Views)
Hi Ed,
Setting up a task in MAX or using the DAQ assistant, you can set up an acceleration task fairly easily. Also there are a few examples (more if you have the Sound and Vibration Toolkit) under the NI Example Finder under Hardware Input and Output » DAQmx » Analog Measurement » Acceleration that you could adapt.
To get your measurements into RMS, try using one of the RMS VIs available in LabVIEW. For example try Programming » Waveform » Analog Waveforms » Waveform Measurement » Cycle Average and RMS.vi
PBear
NI RF
(3,568 Views)
