PXI
how can I use PXI-6683h to build a IEEE 1588 network based peer-peer delay mechanism
hi,everyone.I use two pxi 6683h to build a timing communication network based ieee 1588,through WireShark,I found the messages between two timing cards are    sync 、follow_up 、delay_req 、delay_resp ,this means the Default mechanism is
end-end delay mechanism,How can I turn it into a peer-peer delay mechanism?thus the messages will become  sync、Pdelay_req 、Pdelay_resp  and Pdelay_resp_Follow_up。thanks
Message 1 of 9
(3,683 Views)
Hope this tutorial on IEEE 1588 timing and synchronization helps.
http://www.ni.com/tutorial/53115/en/
Message 2 of 9
(3,661 Views)
thanks for your reply.I have already read this tutorial and PXI 6683H manual before,I can't find any solution for my issue.I'm sure this issue can be achieved. but I don't know how to achieve it
Message 3 of 9
(3,658 Views)
anyone?
Message 4 of 9
(3,629 Views)
thanks for yor kindly help.I have already read this question,but it can't help me,there is no solution for my issue.
Message 6 of 9
(3,623 Views)
Message 7 of 9
(3,621 Views)
yes,I have tried all the examples of 6683H in Labview
Message 8 of 9
(3,603 Views)
Did you get a solution for this issue ?
Message 9 of 9
(2,783 Views)
