PXI
What' can cause PXI-1042 power switch LED flashing red?
What causes the PXI-1042 power switch LED flashing red??
My 2 DIO card, PXI-6533, also went unrecognized in the Hardware Device Manager in Windows; are these issues linked together?
(3,550 Views)
Hello Sampan,
The reason that a PXI-1042 would be Flashing Red is due to the power supply outputs not being within the voltage regulation requirements. In this case, the chassis will still power on and function correctly.  However, electronics present in the chassis may be affected by the outputs being out of specification.  You should try removing all of the cards from the chassis except for the Embedded Controller or MXI card, and moving the chassis to another outlet which is on a different physical circuit. If this does not solve the problem please call in to 1-866-ASK-MYNI (1-866-275-6964) to speak with a service coordinator. Thanks again and have a great day!
Nicholas K
(3,541 Views)
